Robust stability under relaxed persistent excitation conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
For linear time-varying systems with a persistently excited state matrix it is well-known that input-to-state stability is recovered. In this note a relaxed condition on persistence of excitation is studied together with related robust stability notions (input-to-state stability and integral input-to-state stability). The results are illustrated by simulations for scalar systems.
Relaxed_PE_ISS_CDC.pdf (1.01 Mo) Télécharger le fichier
hal-01888575 , version 1 (05-10-2018)
Denis Efimov, Nikita Barabanov, Roméo Ortega. Robust stability under relaxed persistent excitation conditions. 57th IEEE Conference on Decision and Control (CDC 2018), Dec 2018, Miami Beach, FL, United States. ⟨10.1109/cdc.2018.8619330⟩. ⟨hal-01888575⟩
76 Consultations
364 Téléchargements
