Nonlinear Acceleration of Momentum and Primal-Dual Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Programming, Series A Année : 2022
We describe a convergence acceleration scheme for multistep optimization algorithms. The extrapolated solution is written as a nonlinear average of the iterates produced by the original optimization algorithm. Our scheme does not need the underlying fixed-point operator to be symmetric, hence handles e.g. algorithms with momentum terms such as Nesterov's accelerated method, or primal-dual methods. The weights are computed via a simple linear system and we analyze performance in both online and offline modes. We use Crouzeix's conjecture to show that acceleration performance is controlled by the solution of a Chebyshev problem on the numerical range of a non-symmetric operator modelling the behavior of iterates near the optimum. Numerical experiments are detailed on image processing problems, logistic regression and neural network training for CIFAR10 and ImageNet.
hal-01893921 , version 1 (11-10-2018)
Raghu Bollapragada, Damien Scieur, Alexandre d'Aspremont. Nonlinear Acceleration of Momentum and Primal-Dual Algorithms. Mathematical Programming, Series A, 2022, pp.1-38. ⟨10.1007/s10107-022-01775-x⟩. ⟨hal-01893921⟩
85 Consultations
0 Téléchargements
