All-automatic 3D BIM modeling of existing buildings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Reconstruction automatique 3D BIM des bâtiments existants
In order to ensure a reliable building life cycle management, it is es-sential to generate an accurate and up-to-date referential mock-up that will be used for renovation, extension and maintenance. Based on this statement, we carried out, in a previous work, a research study in the sake of reconstructing a 3D CAD model from a point cloud acquired using a Lidar. This point cloud is pro-cessed automatically to detect planes and contours and to generate the 3D CAD model. However, during the life cycle of the project, different actors from differ-ent fields intervene on the building, which creates several communication con-flicts, and this means a loss of time, energy and money. In order to ensure a con-structive collaboration and a simplified data exchange between the different con-tributors in the building, we continued our work to propose, in this paper, an au-tomatic conversion of a point cloud to a 3D BIM file. This conversion induces the passage to the standard IFC format and the integration of a valuable knowledge in it. To do so, an automatic classification of contours into architec-tural elements is proposed. It consists in defining a hierarchical classification rule reproducing the human reasoning for classifying the architectural elements. Then, based on the classified set of polygons, an automatic generation of 3D IFC model is proposed.
474419_1_En_6_Chapter.pdf (838.18 Ko) Télécharger le fichier
hal-01903840 , version 1 (24-10-2018)
hal-01903840 , version 2 (26-03-2019)
Paternité
Djamel-Eddine Benarab, William Derigent, David Brie, Vincent Bombardier, André Thomas. All-automatic 3D BIM modeling of existing buildings. 15th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2018, Turin, Italy. pp.56-68, ⟨10.1007/978-3-030-01614-2_6⟩. ⟨hal-01903840v2⟩
265 Consultations
410 Téléchargements
