Internet-Wide Scanners Classification using Gaussian Mixture and Hidden Markov Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Internet-wide scanners are heavily used for malicious activities. This work models, from the scanned system point of view, spatial and temporal movements of network scanning activities, related to the difference of successive scanned IP addresses and timestamps, respectively. Based on real logs of incoming IP packets collected from a darknet, Hidden Markov Models (HMMs) are used to assess what scanning technique is operating. The proposed methodology, using only one of the aforementioned features of the scanning technique, is able to fingerprint what network scanner originated the perceived darknet traffic.
NTMS2018.pdf (379.36 Ko) Télécharger le fichier
hal-01935664 , version 1 (26-11-2018)
  • HAL Id : hal-01935664 , version 1
Giulia de Santis, Abdelkader Lahmadi, Jérôme François, Olivier Festor. Internet-Wide Scanners Classification using Gaussian Mixture and Hidden Markov Models. NTMS 2018 - 9th IFIP International Conference on New Technologies, Mobility and Security, Feb 2018, Paris, France. ⟨hal-01935664⟩
103 Consultations
250 Téléchargements
