Selecting Reduced Models in the Cross-Entropy Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM/ASA Journal on Uncertainty Quantification Année : 2020
This paper deals with the estimation of rare event probabilities using importance sampling (IS), where an {\it optimal} proposal distribution is computed with the cross-entropy (CE) method. Although, IS optimised with the CE method leads to an efficient reduction of the estimator variance, this approach remains unaffordable for problems where the repeated evaluation of the score function represents a too intensive computational effort. This is often the case for score functions related to the solution of a partial differential equation (PDE) with random inputs. This work proposes to alleviate computation by adapting a score function approximation along the CE optimisation process. The score function approximation is obtained by selecting the surrogate of lowest dimensionality, whose accuracy guarantees to pass the current CE optimisation stage. The adaptation of the surrogate relies on certified upper bounds on the error norm. An asymptotic analysis provides some theoretical guarantees on the efficiency and convergence of the proposed algorithm. Numerical results demonstrate the gain brought by the adaptive method in the context of pollution alerts and a system modelled by a PDE.
hal-01939804 , version 1 (29-11-2018)
Patrick Héas. Selecting Reduced Models in the Cross-Entropy Method. SIAM/ASA Journal on Uncertainty Quantification, 2020, 8 (2), pp.511-538. ⟨10.1137/18M1192500⟩. ⟨hal-01939804⟩
81 Consultations
0 Téléchargements
