Iterative Calculation of Sum Of Squares - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We propose an iterative algorithm for the calculations of sum of squares of polynomials, reformulated as positive interpolation. The method is based on the definition of a dual functional $G$. The domain of $G$, the boundary of the domain and the boundary at infinity are analyzed in details. In the general case, $G$ is closed convex. For univariate polynomials in the context of the Lukacs representation, $G$ is coercive and strictly convex which yields a unique critical point. Various descent algorithms are evoked. Numerical examples are provided, for univariate and bivariate polynomials.
sumofsquares.pdf (1.12 Mo) Télécharger le fichier
hal-01946539 , version 1 (06-12-2018)
hal-01946539 , version 2 (07-12-2018)
hal-01946539 , version 3 (19-07-2019)
hal-01946539 , version 4 (07-01-2020)
hal-01946539 , version 5 (15-03-2020)
Bruno Després, Maxime Herda. Iterative Calculation of Sum Of Squares. 2018. ⟨hal-01946539v1⟩
364 Consultations
804 Téléchargements
