Computation of sum of squares polynomials from data points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We propose an iterative algorithm for the numerical computation of sums of squares of polynomials approximating given data at prescribed interpolation points. The method is based on the definition of a convex functional $G$ arising from the dualization of a quadratic regression over the Cholesky factors of the sum of squares decomposition. In order to justify the construction, the domain of $G$, the boundary of the domain and the behavior at infinity are analyzed in details. When the data interpolate a positive univariate polynomial, we show that in the context of the Lukacs sum of squares representation, $G$ is coercive and strictly convex which yields a unique critical point and a corresponding decomposition in sum of squares. For multivariate polynomials which admit a decomposition in sum of squares and up to a small perturbation of size $\varepsilon$, $G^\varepsilon$ is always coercive and so it minimum yields an approximate decomposition in sum of squares. Various unconstrained descent algorithms are proposed to minimize $G$. Numerical examples are provided, for univariate and bivariate polynomials.
paper.pdf (1.14 Mo) Télécharger le fichier
hal-01946539 , version 1 (06-12-2018)
hal-01946539 , version 2 (07-12-2018)
hal-01946539 , version 3 (19-07-2019)
hal-01946539 , version 4 (07-01-2020)
hal-01946539 , version 5 (15-03-2020)
Bruno Després, Maxime Herda. Computation of sum of squares polynomials from data points. 2019. ⟨hal-01946539v4⟩
364 Consultations
804 Téléchargements
