On homogeneity of discrete-time systems: stability and convergence rates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2019
A new definition of homogeneity for discrete-time systems is introduced. As in the continuous-time case, the property can be verified algebraically in the transition map of the system, and it implies that a dilation of the initial conditions leads to a scaling of the trajectory. Stability properties and convergence rates of the system's solutions can be established by considering only the homogeneity degree. The existence of homogeneous Lyapunov and Lyapunov-like functions is proven.
_Root.pdf (592.62 Ko) Télécharger le fichier
hal-01996519 , version 1 (28-01-2019)
Tonametl Sanchez, Denis Efimov, Andrey Polyakov, Jaime Moreno, Wilfrid Perruquetti. On homogeneity of discrete-time systems: stability and convergence rates. International Journal of Robust and Nonlinear Control, 2019, 29 (8), pp.2406-2421. ⟨10.1002/rnc.4497⟩. ⟨hal-01996519⟩
110 Consultations
438 Téléchargements
