On robust parameter estimation in finite-time without persistence of excitation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
The problem of adaptive estimation of constant parameters in the linear regressor model is studied without the hypothesis that regressor is Persistently Excited (PE). First, the initial vector estimation problem is transformed to a series of the scalar ones using the method of Dynamic Regressor Extension and Mixing (DREM). Second, several adaptive estimation algorithms are proposed for the scalar scenario. In such a case, if the regressor may be nullified asymptotically or in a finite time, then the problem of estimation is also posed on a finite interval of time. Robustness of the proposed algorithms with respect to measurement noise and exogenous disturbances is analyzed. The efficiency of the designed estimators is demonstrated in numeric experiments for an academic example.
FT_Adaptive_J.pdf (420.51 Ko) Télécharger le fichier
hal-01998043 , version 1 (29-01-2019)
  • HAL Id : hal-01998043 , version 1
Jian Wang, Denis Efimov, Alexey A. Bobtsov. On robust parameter estimation in finite-time without persistence of excitation. 2019. ⟨hal-01998043⟩
104 Consultations
485 Téléchargements
