Modelling adhesion-independent cell migration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2020
A two-dimensional mathematical model for cells migrating without adhesion capabilities is presented and analyzed. Cells are represented by their cortex, which is modelled as an elastic curve, subject to an internal pressure force. Net polymerization or depoly-merization in the cortex is modelled via local addition or removal of material, driving a cortical flow. The model takes the form of a fully nonlinear degenerate parabolic system. An existence analysis is carried out by adapting ideas from the theory of gradient flows. Numerical simulations show that these simple rules can account for the behavior observed in experiments, suggesting a possible mechanical mechanism for adhesion-independent motility.
JPRSS.2019 (1).pdf (1.64 Mo) Télécharger le fichier
hal-02076901 , version 1 (22-03-2019)
hal-02076901 , version 2 (29-01-2020)
Gaspard Jankowiak, Diane Peurichard, Anne Reversat, Christian Schmeiser, Michael Sixt. Modelling adhesion-independent cell migration. Mathematical Models and Methods in Applied Sciences, In press, ⟨10.1142/S021820252050013X⟩. ⟨hal-02076901v2⟩
189 Consultations
129 Téléchargements
