Finite-time parameter estimation without persistence of excitation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jian Wang
  • Fonction : Auteur
  • PersonId : 737345
  • IdHAL : jian-wang
The problem of adaptive estimation of constant parameters in the linear regressor model is studied without the hypothesis that regressor is Persistently Excited (PE). First, the initial vector estimation problem is transformed to a series of the scalar ones using the method of Dynamic Regressor Extension and Mixing (DREM). Second, several adaptive estimation algorithms are proposed for the scalar scenario. In such a case, if the regressor may be nullified asymptotically or in a finite time, then the problem of estimation is also posed on a finite interval of time. The efficiency of the proposed algorithms is demonstrated in numeric experiments for an academic example.
ECC19_0623_Wang_A.pdf (358.13 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-02084983 , version 1 (30-03-2019)
  • HAL Id : hal-02084983 , version 1
Jian Wang, Denis Efimov, Alexey A. Bobtsov. Finite-time parameter estimation without persistence of excitation. ECC 2019 - European Control Conference, Jun 2019, Naples, Italy. ⟨hal-02084983⟩
108 Consultations
278 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
