Consensus and Flocking under Communication Failures for a Class of Cucker-Smale Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2021
In this paper, we study sufficient conditions for the emergence of asymptotic consensus and flocking in a certain class of non-linear generalised Cucker-Smale systems subject to multiplicative communication failures. Our approach is based on the combination of strict Lyapunov design together with the formulation of a suitable persistence condition for multi-agent systems. The latter can be interpreted as a lower bound on the algebraic connectivity of the time-average of the interaction graph generated by the communication weights, and provides quantitative decay estimates for the variance functional along the solutions of the system.
CSComFail.pdf (304.4 Ko) Télécharger le fichier
hal-02087941 , version 1 (02-04-2019)
hal-02087941 , version 2 (25-10-2019)
hal-02087941 , version 3 (28-05-2020)
hal-02087941 , version 4 (21-09-2020)
hal-02087941 , version 5 (03-05-2021)
Benoît Bonnet, Emilien Flayac. Consensus and Flocking under Communication Failures for a Class of Cucker-Smale Systems. Systems and Control Letters, 2021, 152, pp.104930. ⟨10.1016/j.sysconle.2021.104930⟩. ⟨hal-02087941v5⟩
362 Consultations
132 Téléchargements
