Samples are not all useful: Denoising policy gradient updates using variance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Policy gradient algorithms in reinforcement learning rely on efficiently sampling an environment. Most sampling procedures are based solely on sampling the agent's policy. However, other measures made available through these algorithms could be used in order to improve the sampling prior to each policy update. Following this line of thoughts, we propose a method where a transition is used in the gradient update if it meets a particular criterion, and rejected otherwise. This criterion is the fraction of variance explained ($\mathcal{V}^{ex}$), a measure of the discrepancy between a model and actual samples. $\mathcal{V}^{ex}$ can be used to evaluate the impact each transition will have on the learning. This criterion refines sampling and improves the policy gradient algorithm. In this paper: (1) We introduce and explore $\mathcal{V}^{ex}$, the selection criterion used to improve the sampling procedure. (2) We conduct experiments across a variety of standard benchmark environments, including continuous control problems. Our results show better performance than if we did not use the $\mathcal{V}^{ex}$ criterion for the policy gradient update. (3) We investigate why $\mathcal{V}^{ex}$ gives a good evaluation for the selection of samples that will positively impact the learning. (4) We show how this criterion can be interpreted as a dynamic way to adjust the ratio between exploration and exploitation.
main.pdf (4.97 Mo) Télécharger le fichier
hal-02091547 , version 1 (08-04-2019)
hal-02091547 , version 2 (10-04-2019)
hal-02091547 , version 3 (24-09-2019)
hal-02091547 , version 4 (25-09-2019)
hal-02091547 , version 5 (13-05-2020)
hal-02091547 , version 6 (20-11-2020)
  • HAL Id : hal-02091547 , version 1
Yannis Flet-Berliac, Philippe Preux. Samples are not all useful: Denoising policy gradient updates using variance. 2019. ⟨hal-02091547v1⟩
333 Consultations
690 Téléchargements
