New interface
Conference papers
Only Relevant Information Matters: Filtering Out Noisy Samples to Boost RL
Yannis Flet-Berliac 1, 2, 3, 4 Philippe Preux 1, 2, 3, 4
1 SEQUEL - Sequential Learning
Inria Lille - Nord Europe, CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille - UMR 9189
4 Scool - Scool
Abstract : In reinforcement learning, policy gradient algorithms optimize the policy directly and rely on sampling efficiently an environment. Nevertheless, while most sampling procedures are based on direct policy sampling, self-performance measures could be used to improve such sampling prior to each policy update. Following this line of thought, we introduce SAUNA, a method where non-informative transitions are rejected from the gradient update. The level of information is estimated according to the fraction of variance explained by the value function: a measure of the discrepancy between V and the empirical returns. In this work, we use this metric to select samples that are useful to learn from, and we demonstrate that this selection can significantly improve the performance of policy gradient methods. In this paper: (a) We define SAUNA's metric and introduce its method to filter transitions. (b) We conduct experiments on a set of benchmark continuous control problems. SAUNA significantly improves performance. (c) We investigate how SAUNA reliably selects samples with the most positive impact on learning and study its improvement on both performance and sample efficiency.
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-02091547
Contributor : Yannis Flet-Berliac Connect in order to contact the contributor
Submitted on : Friday, November 20, 2020 - 4:58:52 PM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
File
sauna_ijcai_camera_ready.pdf
Identifiers
Citation
Yannis Flet-Berliac, Philippe Preux. Only Relevant Information Matters: Filtering Out Noisy Samples to Boost RL. IJCAI 2020 - International Joint Conference on Artificial Intelligence, Jul 2020, Yokohama, Japan. ⟨10.24963/ijcai.2020/376⟩. ⟨hal-02091547v6⟩
Share
Metrics
Record views
310
Files downloads
637
