Null controllability of a parabolic coupled system with control under constraints - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2019
We prove the null controllability of a parabolic system. The single control is common to both PDEs, distributed and subject to constraints. The studied model can be applied in dynamics of biological systems or in physics. First we study the problem associated to a similar linearized system. Then appropriate Carleman inequalities and a fixed-point argument are used to prove the null controllability resuts.
No file
Dates and versions
hal-02098372 , version 1 (12-04-2019)
Identifiers
  • HAL Id : hal-02098372 , version 1
Cite
Carole Louis-Rose. Null controllability of a parabolic coupled system with control under constraints. International Conference on Applied Mathematcs and Numerical Methods (ICAMNM 2018), Oct 2018, Craiova, Romania. pp. 146-158. ⟨hal-02098372⟩
85 View
0 Download
Share
