Weakening of the subpolar gyre as a key driver of North Atlantic seabird demography: a case study with Brünnich’s guillemots in Svalbard - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Marine Ecology Progress Series Année : 2017
The Arctic is experiencing environmental changes at unprecedented rates. These changes are spreading throughout the entire food web, affecting apex predators such as seabirds. Brünnich’s guillemot Uria lomvia populations in Svalbard archipelago have significantly declined since the mid-1990s. For long-lived species such as seabirds, population growth rate is highly sensitive to changes in adult survival rates, and slight changes in survival may have large consequences at the population level. Adult survival rates, were estimated for Brünnich’s guillemots individually marked and monitored from 1986 to 2011 at Bjørnøya, Svalbard. While survival appeared to be repeatedly high (mean ± SE; 95 ± 1%) from 1986 to 1995-98 (transitional years, when Svalbard guillemot colonies started to decline), it dropped by 9-12% over the period 1995-98 to 2011. This decline coincided with the occurrence of an abrupt ecosystem shift in the North Atlantic Ocean in the mid-1990s and the weakening of the Atlantic subpolar gyre. Variations in the subpolar gyre index (SGI) were significantly associated with inter-annual variation in guillemot annual survival, and a strong gyre (i.e. cold waters on guillemot wintering grounds) was associated with high adult survival. Our results, combined with other studies, suggest that the SGI may be an important global proxy to assess oceanographic conditions and changes in marine ecosystems in the North Atlantic.
Fluhr MEPS 2017.pdf (484.42 Ko) Télécharger le fichier
hal-02104969 , version 1 (19-04-2019)
J Fluhr, H Strøm, Roger Pradel, Olivier Duriez, G. Beaugrand, et al.. Weakening of the subpolar gyre as a key driver of North Atlantic seabird demography: a case study with Brünnich’s guillemots in Svalbard. Marine Ecology Progress Series, 2017, 563, pp.1-11. ⟨10.3354/meps11982⟩. ⟨hal-02104969⟩
272 Consultations
115 Téléchargements
