Improving Rigid-Body Registration Based on Points Affected by Bias and Noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The task of registering two coordinate frames is frequently accomplished by measuring the same set of points in both frames. Noise and possible bias in the measured locations degrade the quality of registration. It was shown that the performance of registration may be improved by filtering out noise from repeated measurements of the points, calculating small corrections to the mean locations and restoring rigid-body condition. In the current study, we investigate experimental conditions in which improvement in registration can still be achieved without cumbersome collection of repeated measurements. We show that for sufficiently small noise relative to bias, the corrections calculated from a single measurement of points can be used and still lead to the improved registration.
478022_1_En_20_Chapter.pdf (592.77 Ko) Télécharger le fichier
hal-02115836 , version 1 (30-04-2019)
Paternité
Marek Franaszek, Gerry S. Cheok. Improving Rigid-Body Registration Based on Points Affected by Bias and Noise. 8th International Precision Assembly Seminar (IPAS), Jan 2018, Chamonix, France. pp.226-234, ⟨10.1007/978-3-030-05931-6_20⟩. ⟨hal-02115836⟩
23 Consultations
23 Téléchargements
