Survival criterion for a population subject to selection and mutations ; Application to temporally piecewise constant environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Real World Applications Année : 2020
We study a parabolic Lotka-Volterra type equation that describes the evolution of a population structured by a phenotypic trait, under the effects of mutations and competition for resources modelled by a nonlocal feedback. The limit of small mutations is characterized by a Hamilton-Jacobi equation with constraint that describes the concentration of the population on some traits. This result was already established in [BP08, BMP09, LMP11] in a time-homogenous environment, when the asymptotic persistence of the population was ensured by assumptions on either the growth rate or the initial data. Here, we relax these assumptions to extend the study to situations where the population may go extinct at the limit. For that purpose, we provide conditions on the initial data for the asymptotic fate of the population. Finally, we show how this study for a time-homogenous environment allows to consider temporally piecewise constant environments
CEM_submitted.pdf (977.92 Ko) Télécharger le fichier
hal-02126707 , version 1 (12-05-2019)
hal-02126707 , version 2 (23-11-2020)
Manon Costa, Christèle Etchegaray, Sepideh Mirrahimi. Survival criterion for a population subject to selection and mutations ; Application to temporally piecewise constant environments. Nonlinear Analysis: Real World Applications, In press, 59, ⟨10.1016/j.nonrwa.2020.103239⟩. ⟨hal-02126707v2⟩
283 Consultations
159 Téléchargements
