Equivalent multipolar point-source modeling of small spheres for fast and accurate electromagnetic wave scattering computations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Wave Motion Année : 2020
Modélisation par sources ponctuelles multipolaires équivalentes de petites sphères pour le calcul rapide et précis de la diffraction des ondes électromagnétiques
In this paper, we develop reduced models to approximate the solution of the electromagnetic scattering problem in an unbounded domain which contains a small perfectly conducting sphere. Our approach is based on the method of matched asymptotic expansions. This method consists in defining an approximate solution using multi-scale expansions over outer and inner fields related in a matching area. We make explicit the asymptotics up to the second order of approximation for the inner expansion and up to the fifth order for the outer expansion. We validate the results with numerical experiments which illustrate theoretical orders of convergence for the asymptotic models requiring negligible computational cost.
Preprint_Hal.pdf (993.82 Ko) Télécharger le fichier
hal-02139201 , version 1 (24-05-2019)
hal-02139201 , version 2 (04-09-2019)
Justine Labat, Victor Péron, Sébastien Tordeux. Equivalent multipolar point-source modeling of small spheres for fast and accurate electromagnetic wave scattering computations. Wave Motion, 2020, ⟨10.1016/j.wavemoti.2019.102409⟩. ⟨hal-02139201v2⟩
385 Consultations
250 Téléchargements
