Remarks about spatially structured SI model systems with cross diffusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2019
One of the simplest deterministic mathematical model for the spread of an epidemic disease is the so-called SI system made of two Ordinary Differential Equations. It exhibits simple dynamics: a bifurcation parameter T0 yielding persistence of the disease when T0>1, else extinction occurs. A natural question is whether this gentle dynamic can be disturbed by spatial diffusion. It is straightforward to check it is not feasible for linear/nonlinear diffusions. When cross diffusion is introduced for suitable choices of the parameter data set this persistent state of the ODE model system becomes linearly unstable for the resulting initial and no-flux boundary value problem. On the other hand “natural” weak solutions can be defined for this initial and no-flux boundary value problem and proved to exist provided nonlinear and cross diffusivities satisfy some constraints. These constraints are not fully met for the parameter data set yielding instability. A remaining open question is: to which solutions does this apply? Periodic behaviors are observed for a suitable range of cross diffusivities.
Fichier non déposé
hal-02142018 , version 1 (28-05-2019)
Veronica Anaya, Mostafa Bendahmane, Michel Langlais, Mauricio Sepulveda. Remarks about spatially structured SI model systems with cross diffusion. B. N. Chetverushki; W. Fitzgibbon; Y.A. Kuznetsov; P. Neittaanmäki; J. Periaux; O. Pironneau. Contributions to Partial Differential Equations and Applications, 47, Springer, pp.21, 2019, Computational Methods in Applied Sciences, ⟨10.1007/978-3-319-78325-3_5⟩. ⟨hal-02142018⟩
49 Consultations
0 Téléchargements
