Make false and true first-class language features - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
In its London 2019 meeting, WG14 has found consensus to elevate false and true to proper keywords. This is only a first step to make these constants first-class language features and to achieve a full compatibility with C++. Therefore we need also to change their type, namely to change them from int to bool, and a deprecation of their use in contexts which are non-logical.
n2393+appendix.pdf (384.93 Ko) Télécharger le fichier
hal-02167916 , version 1 (28-06-2019)
hal-02167916 , version 2 (25-11-2019)
hal-02167916 , version 3 (13-01-2022)
hal-02167916 , version 4 (06-10-2022)
  • HAL Id : hal-02167916 , version 1
Jens Gustedt. Make false and true first-class language features. [Research Report] N2393, ISO JTC1/SC22/WG14. 2019. ⟨hal-02167916v1⟩
113 Consultations
68 Téléchargements
