Make false and true first-class language features - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
In its London~2019 meeting, WG14 has found consensus to elevate false and true to proper keywords. By following the proposal of N2229 (vote in the Brno 2018 meeting of WG14), we should also change their type from int to bool.
n2458+appendix.pdf (378.58 Ko) Télécharger le fichier
hal-02167916 , version 1 (28-06-2019)
hal-02167916 , version 2 (25-11-2019)
hal-02167916 , version 3 (13-01-2022)
hal-02167916 , version 4 (06-10-2022)
  • HAL Id : hal-02167916 , version 2
Jens Gustedt. Make false and true first-class language features: proposal for C2x. [Research Report] N2458, ISO JTC1/SC22/WG14. 2019. ⟨hal-02167916v2⟩
113 Consultations
68 Téléchargements
