An adaptive FIR filter for trajectory prediction and latency reduction in direct Human-Computer interactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Control Engineering Practice Année : 2019
The problem of latency reduction in direct Human-Computer interactions is considered. The proposed method is based on a frequency-domain approximation of a non-causal ideal predictor with a finite impulse response filter. Given a sufficiently rich dataset, the parameters of the filter can be either optimized off-line or tuned on-line with the proposed adaptive algorithm. The performance of the proposed solution is evaluated in an experimental study consisting of drawings on a touchscreen.
_AdaptiveFIR_CEP_rev2_v1.pdf (435.81 Ko) Télécharger le fichier
hal-02189181 , version 1 (19-07-2019)
Stanislav Aranovskiy, Rosane Ushirobira, Denis Efimov, Géry Casiez. An adaptive FIR filter for trajectory prediction and latency reduction in direct Human-Computer interactions. Control Engineering Practice, 2019, 91, pp.104093. ⟨10.1016/j.conengprac.2019.07.011⟩. ⟨hal-02189181⟩
214 Consultations
447 Téléchargements
