MojiBoard: Generating Parametric Emojis with Gesture Keyboards - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Inserting emojis can be cumbersome when users must swap through panels. From our survey, we learned that users often use a series of consecutive emojis to convey rich, nuanced non-verbal expressions such as emphasis, change of expressions, or micro stories. We introduce MojiBoard, an emoji entry technique that enables users to generate dynamic parametric emojis from a gesture keyboard. With MojiBoard, users can switch seamlessly between typing and parameterizing emojis
mojiboard-generating-parametric_V12_FINAL.pdf (2.56 Mo) Télécharger le fichier
hal-02279111 , version 1 (05-09-2019)
Jessalyn Alvina, Chengcheng Qu, Joanna Mcgrenere, Wendy Mackay. MojiBoard: Generating Parametric Emojis with Gesture Keyboards. CHI 2019 - The ACM CHI Conference on Human Factors in Computing Systems, May 2019, Glasgow, United Kingdom. pp.1-6, ⟨10.1145/3290607.3312771⟩. ⟨hal-02279111⟩
88 Consultations
323 Téléchargements
