Bilinear local controllability to the trajectories of the Fokker-Planck equation with a localized control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales de l'Institut Fourier Année : 2022
This work is devoted to the control of the Fokker-Planck equation, posed on a smooth bounded domain of R^d, with a localized drift force. We prove that this equation is locally controllable to regular nonzero trajectories. Moreover, under some conditions, we explain how to reduce the number of controls around the reference control. The results are obtained thanks to a standard linearization method and the fictitious control method. The main novelties are twofold. First, the algebraic solvability is performed and used directly on the adjoint problem. We then prove a new Carleman inequality for the heat equation with a space-time varying first-order term: the right-hand side is the gradient of the solution localized on an open subset. We finally give an example of regular trajectory around which the Fokker-Planck equation is not controllable with a reduced number of controls, to highlight that our conditions are relevant.
FP-black.pdf (395.02 Ko) Télécharger le fichier
hal-02280501 , version 1 (06-09-2019)
hal-02280501 , version 2 (20-10-2020)
hal-02280501 , version 3 (20-11-2020)
hal-02280501 , version 4 (16-03-2021)
Michel Duprez, Pierre Lissy. Bilinear local controllability to the trajectories of the Fokker-Planck equation with a localized control. Annales de l'Institut Fourier, 2022, 72 (4), pp. 1621-1659. ⟨10.5802/aif.3501⟩. ⟨hal-02280501v4⟩
210 Consultations
192 Téléchargements
