Adaptive hierarchical subtensor partitioning for tensor compression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2021
In this work a numerical method is proposed to compress a tensor by constructing a piece-wise tensor approximation. This is defined by partitioning a tensor into sub-tensors and by computing a low-rank tensor approximation (in a given format) in each sub-tensor. Neither the partition nor the ranks are fixed a priori, but, instead, are obtained in order to fulfill a prescribed accuracy and optimize, to some extent, the storage. The different steps of the method are detailed and some numerical experiments are proposed to assess its performances.
preprint.pdf (2.12 Mo) Télécharger le fichier
hal-02284456 , version 1 (11-09-2019)
Virginie Ehrlacher, Laura Grigori, Damiano Lombardi, Hao Song. Adaptive hierarchical subtensor partitioning for tensor compression. SIAM Journal on Scientific Computing, 2021, ⟨10.1137/19M128689X⟩. ⟨hal-02284456⟩
452 Consultations
618 Téléchargements
