Using Maple to analyse parallel robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2020
We present the SIROPA Maple Library which has been designed to study serial and parallel manipulators at the conception level. We show how modern algorithms in Computer Algebra can be used to study the workspace, the joint space but also the existence of some physical capabilities w.r.t. to some design parameters left as degree of freedom for the designer of the robot.
2019_Maple_Conference.pdf (1.76 Mo) Télécharger le fichier
hal-02289699 , version 1 (18-09-2019)
Damien Chablat, Guillaume Moroz, Fabrice Rouillier, Philippe Wenger. Using Maple to analyse parallel robots. Jürgen Gerhard; Ilias Kotsireas. Maple in Mathematics Education and Research, Springer, Cham, pp.50-64, 2020, Maple in Mathematics Education and Research, 978-3-030-41257-9. ⟨10.1007/978-3-030-41258-6_4⟩. ⟨hal-02289699⟩
245 Consultations
345 Téléchargements
