Shifted shock-fitting: a new paradigm to handle shock waves for Euler equations
A novel shock-fitting technique, named "shifted shock-fitting", has been implemented on two-dimensional unstructured grids to deal with shocks by treating them as they were immersed boundary. The new algorithm is aimed at coupling a floating shock-fitting technique with the shifted boundary method, so far introduced only to simulate flows with embedded boundaries.
