Robust Control of a Competitive Environment in the Chemostat using Discontinuous Control Laws - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work addresses the problem of robust stabilization of the concentration of two different species competing for a single limiting substrate. This stabilization is performed by means of discontinuous feedback control laws that ensure coexistence of all species. The control laws are designed considering bounded uncertainties on the kinetic rates.
_Robust_CDC2019.pdf (566.96 Ko) Télécharger le fichier
hal-02308076 , version 1 (08-10-2019)
  • HAL Id : hal-02308076 , version 1
  • WOS : 000560779000003
Alex dos Reis de Souza, Denis Efimov, Andrey Polyakov, Jean-Luc Gouzé. Robust Control of a Competitive Environment in the Chemostat using Discontinuous Control Laws. CDC 2019 - 58th IEEE Conference on Decision and Control, Dec 2019, Nice, France. ⟨hal-02308076⟩
147 Consultations
214 Téléchargements
