Adaptive force biasing algorithms: new convergence results and tensor approximations of the bias - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
A modification of the Adaptive Biasing Force method is introduced, in which the free energy is approximated by a sum of tensor products of one-dimensional functions. This enables to handle a larger number of reaction coordinates than the classical algorithm. We prove the algorithm is well-defined and prove the long-time convergence toward a regularized version of the free energy for an idealized version of the algorithm. Numerical experiments demonstrate that the method is able to capture correlations between reaction coordinates.
TABF.pdf (1.14 Mo) Télécharger le fichier
TABF (1).pdf (1.14 Mo) Télécharger le fichier
hal-02314426 , version 1 (13-12-2019)
hal-02314426 , version 2 (20-07-2020)
hal-02314426 , version 3 (19-11-2021)
  • HAL Id : hal-02314426 , version 1
Virginie Ehrlacher, Tony Lelièvre, Pierre Monmarché. Adaptive force biasing algorithms: new convergence results and tensor approximations of the bias. 2019. ⟨hal-02314426v1⟩
Collections
UNIV-PARIS7
409 Consultations
190 Téléchargements
