Adaptive force biasing algorithms: new convergence results and tensor approximations of the bias - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
A modification of the Adaptive Biasing Force method is introduced, in which the free energy is approximated by a sum of tensor products of one-dimensional functions. This enables to handle a larger number of reaction coordinates than the classical algorithm. We prove the algorithm is well-defined and prove the long-time convergence toward a regularized version of the free energy for an idealized version of the algorithm. Numerical experiments demonstrate that the method is able to capture correlations between reaction coordinates.
TABF_HAL_apres_soumission_v2.pdf (1.17 Mo) Télécharger le fichier
hal-02314426 , version 1 (13-12-2019)
hal-02314426 , version 2 (20-07-2020)
hal-02314426 , version 3 (19-11-2021)
  • HAL Id : hal-02314426 , version 2
Virginie Ehrlacher, Tony Lelièvre, Pierre Monmarché. Adaptive force biasing algorithms: new convergence results and tensor approximations of the bias. 2020. ⟨hal-02314426v2⟩
409 Consultations
190 Téléchargements
