A hybrid high-order method for flow simulations in discrete fracture networks. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2021
We are interested in solving flow in large trimensional Discrete Fracture Networks (DFN) with the hybrid high-order (HHO) method. The objectives of this paper are: (1) to demonstrate the benefit of using a high-order method for computing macroscopic quantities, like the equivalent permeability of fracture rocks; (2) to present the computational efficiency of our C++ software, NEF++, which implements the solving of flow in fractures based on the HHO method.
main-article.pdf (1.34 Mo) Télécharger le fichier
hal-02315491 , version 1 (17-12-2019)
hal-02315491 , version 2 (20-12-2019)
hal-02315491 , version 3 (21-12-2019)
hal-02315491 , version 4 (20-02-2020)
hal-02315491 , version 5 (26-05-2020)
Paternité
Florent Hédin, Géraldine Pichot, Alexandre Ern. A hybrid high-order method for flow simulations in discrete fracture networks.. Numerical Mathematics and Advanced Applications ENUMATH 2019, 139, Springer International Publishing, pp.521-529, 2021, Lecture Notes in Computational Science and Engineering, ⟨10.1007/978-3-030-55874-1_51⟩. ⟨hal-02315491v5⟩
210 Consultations
327 Téléchargements
