Computing AES related-key differential characteristics with constraint programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Artificial Intelligence Année : 2020
Cryptanalysis aims at testing the properties of encryption processes, and this usually implies solving hard optimization problems. In this paper, we focus on related-key differential attacks for the Advanced Encryption Standard (AES), which is the encryption standard for block ciphers. To mount these attacks, cryptanalysts need to solve the optimal related-key differential characteristic problem. Dedicated approaches do not scale well for this problem, and need weeks to solve its hardest instances. In this paper, we improve existing Constraint Programming (CP) approaches for computing optimal related-key differential characteristics: we add new constraints that detect inconsistencies sooner, and we introduce a new decomposition of the problem in two steps. These improvements allow us to compute all optimal related-key differential characteristics for AES-128, AES-192 and AES-256 in a few hours.
main.pdf (489.22 Ko) Télécharger le fichier
hal-02327893 , version 1 (23-10-2019)
Paternité
David Gérault, Pascal Lafourcade, Marine Minier, Christine Solnon. Computing AES related-key differential characteristics with constraint programming. Artificial Intelligence, 2020, 278, pp.103183 (24). ⟨10.1016/j.artint.2019.103183⟩. ⟨hal-02327893⟩
609 Consultations
1027 Téléchargements
