TDG method for Friedrichs systems and the P N model in 2D - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
The recent advances about the construction of a Trefftz Discontinuous Galerkin (TDG) method to a class of Friedrichs systems coming from linear transport with relaxation are presented in a comprehensive setting. Application to the 2D P N model are discussed , together with the derivation of new high order convergence estimates and new numerical results for the P 1 and P 3 models. More numerical results in dimension 2 illustrate the theoretical properties.
TDGPN_3.pdf (1.5 Mo) Télécharger le fichier
hal-02372279 , version 1 (20-11-2019)
hal-02372279 , version 2 (18-09-2020)
  • HAL Id : hal-02372279 , version 1
Christophe Buet, Bruno Després, Guillaume Morel. TDG method for Friedrichs systems and the P N model in 2D. 2019. ⟨hal-02372279v1⟩
Collections
UNIV-PARIS7
192 Consultations
192 Téléchargements
