Uncertainty quantification in a macroscopic traffic flow model calibrated on GPS data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Biosciences and Engineering Année : 2020
The objective of this paper is to analyze the inclusion of one or more random parameters into the deterministic Lighthill-Whitham-Richards traffic flow model and use a semi-intrusive approach to quantify uncertainty propagation. To verify the validity of the method, we test it against real data coming from vehicle embedded GPS systems, provided by Autoroutes Trafic.
BDG-MBEpreprint.pdf (1.67 Mo) Télécharger le fichier
hal-02379540 , version 1 (25-11-2019)
  • HAL Id : hal-02379540 , version 1
Enrico Bertino, Régis Duvigneau, Paola Goatin. Uncertainty quantification in a macroscopic traffic flow model calibrated on GPS data. Mathematical Biosciences and Engineering, 2020, 17 (2), pp.1511-1533. ⟨hal-02379540⟩
120 Consultations
121 Téléchargements
