Monotone and second order consistent scheme for the two dimensional Pucci equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce a new strategy for the design of second-order accurate discretizations of non-linear second order operators of Bellman type, which preserves degenerate ellipticity. The approach relies on Selling's formula, a tool from lattice geometry, and is applied to the Pucci equation, discretized on a two dimensional Cartesian grid. Numerical experiments illustrate the robustness and the accuracy of the method. Note: An earlier version of this document also discussed the Monge-Ampère PDE. This part has been removed in the revised version in order to comply with the page limit of the journal.
Pucci_Only.pdf (978.25 Ko) Télécharger le fichier
hal-02383521 , version 1 (27-11-2019)
hal-02383521 , version 2 (31-05-2020)
Joseph Frédéric Bonnans, Guillaume Bonnet, Jean-Marie Mirebeau. Monotone and second order consistent scheme for the two dimensional Pucci equation. Numerical Mathematics and Advanced Applications ENUMATH 2019., Sep 2019, Egmond aan Zee, Netherlands. pp 733-742, ⟨10.1007/978-3-030-55874-1_72⟩. ⟨hal-02383521v2⟩
284 Consultations
177 Téléchargements
