Towards a comprehensive impossibility result for string stability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2019
Alain Sarlette
  • Fonction : Auteur
  • PersonId : 10453
  • IdHAL : asarlet
We provide a comprehensive impossibility result towards achieving string stability, i.e. keeping local relative errors in check with local controllers independently of the size of a chain of subsystems. We significantly extend existing results, from the LTI setting to any homogeneous controllers that can be nonlinear, time-varying, and locally communicating. We prove this impossibility for a set of definitions with various norm choices, including the L2-type standard and a BIBO type criterion. All results hold for a general discrete-time controller which should cover most applications.
SubmitIEEE.pdf (575.43 Ko) Télécharger le fichier
hal-02394703 , version 1 (04-12-2019)
Arash Farnam, Alain Sarlette. Towards a comprehensive impossibility result for string stability. IEEE Transactions on Automatic Control, 2019, 65 (4), pp.1652-1659. ⟨10.1109/TAC.2019.2929967⟩. ⟨hal-02394703⟩
45 Consultations
111 Téléchargements
