What You Simulate Is What You Synthesize: Design of a RISC-V Core from C++ Specifications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
main.pdf (95.21 Ko) Télécharger le fichier
hal-02394911 , version 1 (05-12-2019)
  • HAL Id : hal-02394911 , version 1
Simon Rokicki, Davide Pala, Joseph Paturel, Olivier Sentieys. What You Simulate Is What You Synthesize: Design of a RISC-V Core from C++ Specifications. RISC-V Workshop 2019, Jun 2019, Zurich, Switzerland. pp.1-2. ⟨hal-02394911⟩
120 Consultations
1581 Téléchargements
