On an existence theory for a fluid-beam problem encompassing possible contacts
In this paper we consider a coupled system of pdes modelling the interaction between a two-dimensional incompressible viscous fluid and a one-dimensional elastic beam located on the upper part of the fluid domain boundary. We design a functional framework to define weak solutions in case of contact between the elastic beam and the bottom of the fluid cavity. We then prove that such solutions exist globally in time regardless a possible contact by approximating the beam equation by a damped beam and letting this additional viscosity vanishes.
