hetGP: Heteroskedastic Gaussian Process Modeling and Sequential Design in R - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Statistical Software Année : 2021
Robert B. Gramacy
  • Fonction : Auteur
  • PersonId : 1061214
An increasing number of time-consuming simulators exhibit a complex noise structure that depends on the inputs. For conducting studies with limited budgets of evaluations, new surrogate methods are required in order to simultaneously model the mean and variance fields. To this end, we present the hetGP package, implementing many recent advances in Gaussian process modeling with input-dependent noise. First, we describe a simple, yet efficient, joint modeling framework that relies on replication for both speed and accuracy. Then we tackle the issue of data acquisition leveraging replication and exploration in a sequential manner for various goals, such as for obtaining a globally accurate model, for optimization, or for contour finding. Reproducible illustrations are provided throughout.
hetGP_vignette.pdf (775.31 Ko) Télécharger le fichier
hal-02414688 , version 1 (18-12-2019)
Mickael Binois, Robert B. Gramacy. hetGP: Heteroskedastic Gaussian Process Modeling and Sequential Design in R. Journal of Statistical Software, 2021, 98 (13), pp.1--44. ⟨10.18637/jss.v098.i13⟩. ⟨hal-02414688⟩
140 Consultations
378 Téléchargements
