On qualitative properties of single-delay linear retarded differential equations: Characteristic roots of maximal multiplicity are necessarily dominant
This paper presents necessary and sufficient conditions for the existence of a real root of maximal multiplicity in the spectrum of a linear time-invariant single-delay equation of retarded type. We also prove that this root is always strictly dominant, and hence determines the asymptotic behavior of the system. These results are based on improved a priori bounds on the imaginary part of roots on the complex right half-plane.
root.pdf (178.06 Ko)
Télécharger le fichier
Figures/bounds2.pgf (261.83 Ko)
Figures/bounds3.pgf (159.25 Ko)
Figures/sols.pgf (36.68 Ko)
Figures/zeros.pgf (34.18 Ko)
