A finite volume method for a convection- diffusion equation involving a Joule term - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work is devoted to a Finite Volume method to approximate the solution of a convection-diffusion equation involving a Joule term. We propose a way 5 to discretize this so-called "Joule effect" term in a consistent way with the non linear diffusion one, in order to ensure some maximum principle properties on the solution. We then investigate the numerical behavior of the scheme on two original benchmarks.
PaperCCEC-FVCA9-hal.pdf (109.41 Ko) Télécharger le fichier
hal-02432936 , version 1 (08-01-2020)
Caterina Calgaro, Emmanuel Creusé. A finite volume method for a convection- diffusion equation involving a Joule term. International Conference on Finite Volumes for Complex Applications IX, Jun 2020, Bergen, Norway. pp.405-413, ⟨10.1007/978-3-030-43651-3_37⟩. ⟨hal-02432936⟩
109 Consultations
340 Téléchargements
