A reduced-order discontinuous Galerkin method based on a Krylov subspace technique in nanophotonics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics and Computation Année : 2019
This paper is concerned with the design of a reduced-order model (ROM) based on a Krylov subspace technique for solving the time-domain Maxwell’s equations coupled to a Drude dispersion model, which are discretized in space by a discontinuous Galerkin (DG) method. An auxiliary differential equation (ADE) method is used to represent the constitutive relation for the dispersive medium. A semi-discrete DG scheme is formulated on an unstructured simplicial mesh, and is combined with a centered scheme for the definition of the numerical fluxes of the electric and magnetic fields on element interfaces. The ROM is established by projecting (Galerkin projection) the global semi-discrete DG scheme onto a low-dimensional Krylov subspace generated by an Arnoldi process. A low-storage Runge-Kutta (LSRK) time scheme is employed in the semi-discrete DG system and ROM. The overall goal is to reduce the computational time while maintaining an acceptable level of accuracy. We present numerical results on 2-D problems to show the effectiveness of the proposed method.
Fichier non déposé
hal-02433050 , version 1 (08-01-2020)
Kun Li, Ting-Zhu Huang, Liang Li, Stéphane Lanteri. A reduced-order discontinuous Galerkin method based on a Krylov subspace technique in nanophotonics. Applied Mathematics and Computation, 2019, 358, pp.128-145. ⟨10.1016/j.amc.2019.04.031⟩. ⟨hal-02433050⟩
54 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
