Survivability in optical networks: a solution for the wavelength continuity constraint case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
hal-02434311 , version 1 (09-01-2020)
  • HAL Id : hal-02434311 , version 1
Nicolas Jara, Hermann Pempelfort, Gerardo Rubino, Reinaldo Vallejos. Survivability in optical networks: a solution for the wavelength continuity constraint case. LADC 2019 - 9th Latin-American Symposium on Dependable Computing, Nov 2019, Natal, Brazil. pp.1-9. ⟨hal-02434311⟩
50 Consultations
289 Téléchargements
