On the saddlepoint approximation of the dependence testing bound in memoryless channels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces an upper-bound on the absolute difference between: $(a)$ the cumulative distribution function (c.d.f.) of the sum of a finite number of independent and identically distributed (i.i.d) random variables; and $(b)$ a saddlepoint approximation of such c.d.f. This upperbound is general and particularly precise in the regime of large deviations. This result is used to study the dependence testing (DT) bound on the minimum decoding error probability (DEP) in memoryless channels. Within this context, the main results include new lower and upper bounds on the DT bound. As a byproduct, an upper bound on the absolute difference between the exact value of the DT bound and its saddlepoint approximation is obtained. Numerical analysis of these bounds are presented for the case of the binary symmetric channel and the additive white Gaussian noise channel, in which the new bounds are observed to be tight.
icc2020.pdf (561.93 Ko) Télécharger le fichier
hal-02457361 , version 1 (28-01-2020)
hal-02457361 , version 2 (03-03-2020)
  • HAL Id : hal-02457361 , version 1
Dadja Anade, Jean-Marie Gorce, Philippe Mary, Samir Perlaza. On the saddlepoint approximation of the dependence testing bound in memoryless channels. ICC 2020 - IEEE International Conference on Communications, Jun 2020, Dublin, Ireland. pp.1-5. ⟨hal-02457361v1⟩
358 Consultations
377 Téléchargements
