Dynamic modeling of cooperative robots holding flexible objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper a method of calculating the inverse and direct dynamic model of cooperative manipulators handling flexible objects is presented. In order to solve the dynamics of this system, the closed chain is divided into two subsystems, one is flexible, representing the object and the other is rigid, representing the tree structure of the two manipulators. The two subsystems are connected by calculating the wrench transmitted by the end effectors. An analytic solution is obtained for the dynamic model. The proposed solution leads to a classification of objects grasped by multiple manipulators.
ICAR15-long.pdf (899.12 Ko) Télécharger le fichier
hal-02459380 , version 1 (29-01-2020)
Philip Long, Wisama Khalil, Philippe Martinet. Dynamic modeling of cooperative robots holding flexible objects. ICAR 2015 - International Conference on Advanced Robotics, Jul 2015, Istanbul, France. pp.182-187, ⟨10.1109/ICAR.2015.7251453⟩. ⟨hal-02459380⟩
42 Consultations
134 Téléchargements
