Comparison of Visual Servoing Techniques : Experimental Results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
In visual servoing applications, two main approaches were de ned by Sanderson and Weiss at the beginning of the eighties: Position Based Control and Image Based Control. The aim of this article is to present di erent control laws using these approaches, and discuss the main advantages and disadvantages of both approaches through experimental results. The target object is composed of four non-coplanar characteristic points. From the projection of these four points in the image frame, the estimate of the Pose of the object in the sensor frame is computed using the Dementhon algorithm.
ecc99.pdf (287.41 Ko) Télécharger le fichier
hal-02465626 , version 1 (04-02-2020)
Philippe Martinet. Comparison of Visual Servoing Techniques : Experimental Results. ECC 1999 - European Control Conference, Aug 1999, Karlsruhe, Germany. pp.4555-4560, ⟨10.23919/ECC.1999.7100053⟩. ⟨hal-02465626⟩
17 Consultations
307 Téléchargements
