Automatic Guidance of a Farm Tractor Relying on a Single CP-DGPS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Autonomous Robots Année : 2002
Precision agriculture involves very accurate farm vehicle control along recorded paths, which are not necessarily straight lines. In this paper, we investigate the possibility of achieving this task with a CP-DGPS as the unique sensor. The vehicle heading is derived according to a Kalman state reconstructor, and a nonlinear velocity independent control law is designed, relying on chained systems properties. Field experiments, demonstrating the capabilities of our guidance system, are reported and discussed.
AR02-Benoit.pdf (604.03 Ko) Télécharger le fichier
hal-02466250 , version 1 (04-02-2020)
B. Thuilot, C. Cariou, P. Martinet, M. Berducat. Automatic Guidance of a Farm Tractor Relying on a Single CP-DGPS. Autonomous Robots, 2002, 13 (1), pp.53-71. ⟨10.1023/A:1015678121948⟩. ⟨hal-02466250⟩
63 Consultations
335 Téléchargements
