On estimation of rates of convergence in Lyapunov-Razumikhin approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2020
Considering a retarded nonlinear system, this note proposes several modifications of the Lyapunov-Razumikhin approach guaranteeing the existence of an upper estimate on convergence rate of the system solutions. The cases of exponential, finite-time and fixed-time (with respect to a ball) convergences are studied. The proposed approach is illustrated by simulation of academic examples.
LR_rates.pdf (431.79 Ko) Télécharger le fichier
hal-02493918 , version 1 (28-02-2020)
Denis Efimov, Alexander Aleksandrov. On estimation of rates of convergence in Lyapunov-Razumikhin approach. Automatica, 2020, 116, ⟨10.1016/j.automatica.2020.108928⟩. ⟨hal-02493918⟩
60 Consultations
402 Téléchargements
