Ensemble qubit controllability with a single control via adiabatic and rotating wave approximations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Differential Equations Année : 2022
In the physics literature it is common to see the rotating wave approximation and the adiabatic approximation used "in cascade" to justify the use of chirped pulses for two-level quantum systems driven by one external field, in particular when the resonance frequency of the system is not known precisely. Both approximations need relatively long time and are essentially based on averaging theory of dynamical systems. Unfortunately, the two approximations cannot be done independently since, in a sense, the two time scales interact. The purpose of this paper is to study how the cascade of the two approximations can be justified and how large becomes the final time as the fidelity goes to one, while preserving the robustness of the adiabatic strategy. Our first result, based on high-order averaging techniques, gives a precise quantification of the uncertainty interval of the resonance frequency for which the population inversion works. As a byproduct of this result, we prove that it is possible to control an ensemble of spin systems by a single real-valued control, providing a non-trivial extension of a celebrated result of ensemble controllability with two controls by Khaneja and Li.
paper.pdf (708.78 Ko) Télécharger le fichier
hal-02504532 , version 1 (10-03-2020)
hal-02504532 , version 2 (10-05-2021)
Rémi Robin, Nicolas Augier, Ugo Boscain, Mario Sigalotti. Ensemble qubit controllability with a single control via adiabatic and rotating wave approximations. Journal of Differential Equations, 2022, 318, pp.414-442. ⟨10.1016/j.jde.2022.02.042⟩. ⟨hal-02504532v2⟩
472 Consultations
225 Téléchargements
